Your card is a PCI-E card so it will use a PCI=E slot. I have a Asus P5K-C board and it works and fits in no prob, so hopefully you'll be OK.
Ok, ok - cool.
I'll admit I'm a bit aprehnesive, this is my first build from all new parts that are actually costing me for a change! lol
What do you reckon to the DVD drive being SATA, should be fine, better than IDE... Do I need to worry about jumper settings off the bat or not?
Here is a complete rundown list of my full order, does it look fine and dandy to you?
My main focus is getting it up and running when it arrvies, I'll worry about overclocking several days later I think. Priority is to get everything installed satisfactory, newest thing to me would be applying the cooler to the CPU with the thermal paste. I shall have a look back and fine some video or something for that. Grab driver updates etc, maybe play some Gears of War before overclocking and see how it handles (before I **** everything up with overclocking lol)... another thing, does overclocking in any way void warranty?
1 LN20936 512MB MSI 8800GTS ShaderOC, PCI-E 2.0 (x16), Mem 1940MHz, GDDR3, GPU 650MHz, 2x Dual Link DVI-I/HDTV
£179.00
1 LN19715 Asus P5K SE, iP35, S 775, PCI-E (x16), DDR2 1066/667/800MHz, SATA II, ATX
£53.35
1 LN19302 4GB (2x2GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-18
£57.64
1 LN17166 Microsoft Windows Vista Home Premium 64Bit 1Pk OEM (DVD)
£53.99
1 LN20707 Intel Core 2 Quad-Core Q6600 G0 SLACR, 95W, S775, 2.40 GHz, 1066MHz FSB, 8MB Cache, OEM
£131.39
1 LN13080 Arctic Cooling Freezer 7 Pro - P4 up to 4.4GHz - S775 Dual/Quad Core Ready - The Favourite One!
£12.99
1 LN19849 550w Corsair VX Series PSU, ATX, PS/2, 5 year Warranty
£47.99
1 LN20181 500 GB Seagate ST3500320AS Barracuda 7200.11, SATA II, 7200 rpm, 32MB Cache, 8.5 ms, NCQ
£64.79
1 LN21508 Pioneer DVR-215BK 20x DVD±R, 10x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, SATA, Black, OEM
£17.39
1 LN11644 45cm Akasa SATA/SATAII (3G) Day Glo Blue UV HDD Cable, 1 x R.angle connector with secure latch
£1.95
Net Total £620.48
Carriage £0.00
V.A.T £108.58
TOTAL £729.06
