The Elf
Established Member
Hi guys, I need to get a new computer over the summer as my laptop is playing up, and was thinking I would build my own – as I know a few friends that did it so can help me assemble it, and it seems to be the cheaper option.
I was hoping you would have a look at the components I picked to see if they would all ‘work'.
In terms of budget, I do not have a specific one in mind, I would prefer to get the best value/spec for money within reason.
I will be using Photoshop quite a lot, and a bit of 3D CAD things (Solidworks etc). It would be nice to have it relatively quiet also. Also needs to be able to play HD videos and will be used through a full HD monitor all the time (possibly connecting to two monitors when I get another).
Case – Coolermaster Storm Scout - £70
CM Storm Scout Case - 120mm and 2x 140mm Fans Included | Ebuyer.com
My main criteria for this is a well built solid case, though those carry handles will be very handy as I will be transporting it a fair bit. Some people say this case can't fit some GPUs in it though?
Motherboard – Asus P6T - £150
ASUS P6T iX58 Socket 1366 8 channel audio ATX Motherboard | Ebuyer.com
Have I correctly assumed that the 1366 socket would future proof the computer more?
So yeah, I really just guessed at which one of these, going by the reviews and what seems popular.
CPU – Intel i7 920 2.66Ghz 1366 - £200
Intel Core i7 920 D0 2.66GHz Socket 1366 8MB Cache.. | Ebuyer.com
I would prefer an Intel processor, so this is really the only option except the 2.8Ghz version for an extra £40 – the rest seem a lot more expensive for what they are (I don't plan to overclock)
RAM – OCZ 6GB Gold 1333Mhz- £120
OCZ 6GB (3X2GB) DDR3 1333MHz/PC3-10666 Gold XTC Triple.. | Ebuyer.com
Would it be worth the extra £10 for the ‘Platinum OCZ' version, or the £40 for 2000Mhz?
Drive – Samsung Blu Ray - £45
Samsung SH-B083L 8x Blu-Ray player with DVD±RW.. | Ebuyer.com
Not too worried about this choice, as long as it works its fine, thought at that price maybe worth grabbing a blu ray.
HDD – 2TB WD - £100
Western Digital WD20EARS 2TB Hard Drive SATAII 64MB.. | Ebuyer.com
How much difference does the buffer size make (64Mb for this one), and what is the difference between SATAII and SATAIII? Ideally I would prefer a couple of 1TB drives, but the WD ones seem to be £80 for those, so not really worth it.
PSU - ????
I have no idea what PSU I will need, from browsing the forums I hear a lot of talk about needing good ones – there is a Storm Scout with a bundled ‘Coolermaster Silent Pro 700W modular' for an extra £50 – worth going for do you think?
GPU - ???
Again, I have no idea what the current good ones are, the option to play a few games like call of duty would be nice – so really just want a midrange one, £150 maybe? – a few suggestions with their capabilities would be good
In terms of brand loyalties, I prefer Nvidia as that is what I have always had before in my laptops etc.
Sorry for the very long post, I hope someone has time to give me a few pointers
Thanks, Ed
HDD – 2TB WD - £100
PSU - ????
GPU - ???
Thanks, Ed
