Build my own sub sat pack?
Discussion in 'Subwoofers' started by hermand, May 29, 2002.
  1. hermand
    hermand
    Mar 8, 2002
    43
    London
    I've been looking at upgrading my speakers, and having read some threads here, some of the more senior members seem to suggest:
    (i) All speakers should be identical in so far as they can be
    (ii) Floorstanders can be more tricky to place than smaller speakers.
    I know there are many mid-range sub/sat packages out there (Kef egg etc), but I feel like I want 'proper' speakers, rather than lifestyle type accessories.
    What I was thinking of getting for a 6.1 setup was 3 pairs of B&W 601s2 (Fronts, Centre, Surrounds, Rear Centre) and 1 or 2 Paradigm PDR-10 subs. (i.e. no overpriced dedicated centre)
    Can anyone think why this might be a bad idea (I know the centre won't be magnetically shielded, I don't think that'll be a problem)
    Also, should I set the crossover to be 80Hz?
    (Yes I know I should demo it etc., I would just like a sanity check that I wouldn't be asking for something stupid)
    Herman
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Going for a setup like you´ve mentioned will outperform the likes of the Kef eggs etc
    Identical speakers all round really is the way to. The only problem you´ll get is if the speaker you are going to use as a centre is too close to the tv, you need some space between them to avoid problems.
    Setting the crossover at 80hz should work well for the speakers you´ve chosen.
    And, you´re not asking for anything stupid either, quite the opposite in fact.:)
    cheers
  3. sparkybun
    sparkybun
    Jan 6, 2002
    1,237
    41
    EN8 area
    +23
    Hermand,
    Have you thought of the Kef Q1's. They seem to be getting a very good press at the moment (see Uncle Eric's thread). Apparently you can only buy them in Pairs though (ok if you've got 6.1 system).
