Buget Movie Amp + Spkrs
Discussion in 'AV Receivers & Amplifiers' started by Jonboy, Jun 8, 2004.
  1. Jonboy
    Jonboy
    Jun 8, 2004
    12
    Hia
    Makes good reading this webbie and Ive got some ideas ..
    I dont like second hand or online buying <-- Mostly due to impatience and wanting to get my grubby mits on the new equipment
    My budget is circa 350 ( inc cables expecting 400 )
    Im looking at a number of amps :
    Teac AG10D
    Yamaha RXV640
    Marantz SR4400
    Im 90% movies 10% sound ( prob mtv / vh1 )
    Speakers
    Im looking at
    Yamaha NSP100
    Tannoy FX5.1
    However im contemplating the lower priced Yamahas with the intention to start upgrading them over Christmas ( so I would want good performance in meantime ) ( Id keep the amp)
    Searching the threads the Yamaha has been getting good reviews .. ppl seem quiet on the teacs performance and the Marantaz people rave about but thats the 5400 version
    The alternative is
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=YAM-AV25PACK&clear=
    Which is the same speakers i was thinking with the HTR-5630RDS amp but at £265 that seems a little steep
    The 6.1 is nice to have and I suppose it gives it a bit of future proofness but Im not massivly concerned about it - Id rather focus on better 5.1 sound :)
    Anyway all thoughts greatly appreciated :smashin:
  2. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  3. balders
    balders
    Jul 31, 2001
    449
    28
    +25
    Tha Yam 640 is a good choice for movies. I auditioned one along with a Denon 1804, and both were good sounding amps. I went with the Denon in the end because it had the edge for music.
    One advantage that the Denon had over the Ham was the variable crossover levels, which you may want to consider if you're thinking of getting a sub/sat speaker system. The Yam is fixed at 90 Hz crossover, whereas the Denon can be set to 80/100/120/150, depending on your speaker setup.
    Balders.
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    If I had to choose to keep one of my A/V amps, it'd be the 640. It's poor in stereo, has limited power (especially with 6 channels driven) but just does a fabulous job of throwing noise around the room and putting you right "in the action".
    Go for the DSP version if you don't need a radio - its about £40 cheaper. Take a look at the Denons too.
    DT
  5. Jonboy
    Jonboy
    Jun 8, 2004
    12
    Slight change of plan :
    Denon avr 1604
    Marantz dr 4400
    Pioneer VSX D812 All weighing in at 199
    Which doesnt seem to bad ( small room )
    The pioneer is slightly marked ( doesnt bother me ) hence the price - Im thinking about taking it but I dont see any rave reviews :rolleyes: so that would leave the marantz which would be good
    Any thoughts ? :D
  6. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Get the Pioneer 812, it will slaughter the other 2 amps ;)
  7. Jonboy
    Jonboy
    Jun 8, 2004
    12
    you have convinced me :)
    Ill save myself the 60 notes and pick up the pioneer :)
    BTW taking into account the price differance how does it compare to the 640 ( I loathe to ask that question but I gotta know :) )
    hehe
  8. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  9. @if ®afiq
    @if ®afiq
    May 31, 2004
    576
    +18
  10. Jonboy
    Jonboy
    Jun 8, 2004
    12
    Just got it all setup :)
    Sounds sweet - Wharfedale speakers £100 jobs from superfi link is above - give out some real nice sound to me Only thing would recommend is stands as ive them on the ground at the moment and the sound seems a bit 'low'
    Reciever was the 812 from superfi as i say marked so 1 pence short of 200 but worth every penny imo :)
    Oh now i need a all in one remote :cool:
