Bug in Via Southbridge "exacerbated" by Sblive
Discussion in 'Desktop & Laptop Computers Forum' started by Mattie, Apr 13, 2001.
  1. Mattie
    Mattie
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    mmmmmmm
    I wander if this has anything to do with my problems ? as the hard drive just had a fit and refused to work as ata/100 after a few hours of use !
    Can you keep me informed MATTIE ?
  3. Mattie
    Mattie
    Sure M8.
  4. Mattie
    Mattie
    Seems the problem is easily fixed but requires use of a dangerous little utility called WPCRSET (I can email it to anyone, only 60K) which alters hidden BIOS settings.
    Fri 13/4/01 News at NVMax for more info.
    UPDATE: Easier Method!
    [ 14-04-2001: Message edited by: Mattie ]
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    would like a copy if you do not mind
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Me too please. Thanks.
  7. Mattie
    Mattie
    This page at ViaHardware.com is where I downloaded it (same link as "easier method" above). Scroll down and you'll see "George's patches", that's the easier way. WPCRSET is pretty dangerous - one of the few pieces of software that can permanently damage hardware - so I went for George's solution.
    Hope this Helps
    (I can still email a few people if that link goes down, but I'll probably just post another link)
    Mattie. ;)
