PaddockMonkey
Hi there,
First post here. Thanks for reading!
I've had a Pro-Ject Debut III turntable 12 years and it's finally running out of steam (the platter is struggling to spin and having recently replaced the motor after which it worked for a while it is back to the same problem). So I'm in the market for a new turntable in the €200-350 (£175-270) range. It should have a built-in preamp as I don't have a separate phono stage. I don't need USB output.
Thing is, I recently upgraded the cartridge to an Ortofon 2M Red (and accompanying counterweight) which I would like to reuse. I have a Primare I21 amplifier and B&W 804 speakers.
So any recommendations for the new turntable based on the above? So far I like the look of the Fluance RT81 and I also really like the look of the Rega Planar 1 Plus, though this would probably be outside of my budget.
Thanks in advance,
Daire
Thanks in advance,
Daire
