mushtafa
Established Member
This is a temporary solution until I can afford something better, but I'll be using a JBL GT5-12 car subwoofer - purely because I have it here spare.
I've tried to keep the build as small as possible, but didn't want to go for a full sealed enclosure.
I set about learning how to use WinISD & Sketchup, so had a play with some dimensions, and think I've cracked it. I've opted tor a 4th order. It'll be powered by a plate amp at 130W for the time being. The port air velocity is modelled on the sub being powered with 250W. If I decide to keep it, I'll get a better amp to drive it.
I'm after any advice or suggestions before I build the cabinet.
Not all dimensions are clear to read, but link to download Sketchup .skp Attempt 9.skp
