Budget subwoofer - Rectangular not cube
Discussion in 'Subwoofers' started by craiglad, Jul 29, 2002.
  1. craiglad
    craiglad
    I'm looking for a budget priced sub woofer (about 100 quid) for my surround sound set-up. It needs to be rectangular shape as I'm going to sit it in my television unit (I know it's not ideal, but there is no where else to put it!). Can anyone suggest a decent sub?
    thanks in advance,
    Craiglad.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    You need to ensure that it's magnetically shielded if it is going to be close to your TV and most aren't.
  3. craiglad
    craiglad
    Just had a look on the MS website and noticed that the 308W sub is magneticly shielded, so all may not be lost. All I ned to do now is check that it fits in my tv cabinet....
  4. john87
    john87
    There is no way you can place a subwoofer directly into a cabinet, trust me, it will rattle far too much.
    Mine is placed onto concrete slabs which are on top of squash balls the other side of the room from my book cabinet, and the glass doors still rattle in some parts of the room... now imagine placing the sub directly into the cabinet.
  5. craiglad
    craiglad
    It's a wooden cabinet and I'll probably need to blu tack anything that moves. As I say, it's not the best, but it's either in the cabinet or it's not there at all. You should ahve seen the problems I've had convincing her that I need a speaker on top of the tele and one either side of the sofa! the fairer sex just don't seem to understand the need for this sort of thing although i bet she won't complain once she's heard it in action....
  6. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    The smaller Yamaha subs are rectangular and magnetically shielded.
    I am unsure of model numbers and prices though.
  7. john87
    john87
    There won't be much you can do if each side of the cabinet is vibrating though :p
  8. Tejpal
    Tejpal
  9. Matt F
    Matt F
    Jul 18, 2000
    904
    Chester, UK
    +4
    I tried putting my REL Q200 in my very solidly built wooden TV cabinet (which has no doors and which sits on carpet over a concrete floor) - I blue-tacked it down. That should do the trick I thought - big heavy telly - solid cabinet - nothing should vibrate.
    How to test it - ah - the first track off Massive Attack's Mezzanine album played at a reasonable volume......
    The sub almost ripped the cabinet apart! Loads of resonance and vibration. Basically, it sounded awful.
    You have been warned.
    Matt.
  10. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    It sounds like it is out of your budget, but the MJ Aucoustis Pro 100 (around £500) looks just like a posh coffee table- might help get the missus onto your side? Cracking sound too!
    Edit: scratch that - the new REL Quake at £350 also looks a bit like furniture.......
  11. john87
    john87
    That is what I was expecting craiglad to come back and say after he did it! :eek:
  12. Guest
    It's a male and it's generalizing ;)
    I would love to hear a sub in a cabinet :D ;)
  13. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    It's a female and fighting a losing battle on this one :)
  14. Kronik
    Kronik
    Anyone know where you can buy this 308w? Or any similar products by MS?
