Budget Sub to go with Yamaha 620
Discussion in 'Subwoofers' started by raven219, May 14, 2002.
  1. raven219
    raven219
    Mar 5, 2001
    566
    East Anglia (well someone has to live there!)
    +22
    Having read the forum, the Paradigm seems to be recommended. Two quick questions. Will this sound good with a Yamaha 620 Amp? What does this sound like with music?
    Raven
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Most subs will work well with most amps, just a matter of getting the placement right and fine tuning it.
    Paradigm´s are good subs for the money, PDR10, PS1000 etc
  3. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Some are no good with music because they are too slow and can't keep pace, although they may go down low.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I am not sure what Brox is disagreeing with as the questions asked were "Will the Paradigm work with most amps and is it good with music" and Jase answered the specific question without including irrelevant generalities.
    Yes, the Paradigm will work with all decent amps and the concensus of opinion is that they offer a good range of value for money subwoofers which work well with music and movies.
  5. sofaboy
    sofaboy
    I have the 620 and also the yamaha YST-SW 305 sub, its not that expensive £250 but sounds DA BOMB !!
    i can recommend the 305, I listern to a lot of music and have a Mini Disc and CD unit running through my amp also... the reproduction from my sub is quality......and it has a movie/music setting..... They do a model down from the 305...the 205 which is a 150w, and that would be cheaper
  6. Samir
    Samir
    I would also recommend the PDR 10 or PS 1000. I've owned both of these subs and found them to give amazing results in a movies ans music set up.
    As for these subs not being fast enough. I mainly play Drum & Bass on my set and I've found that this sub has no trouble keeping up with the pace, and if you have ever heard any Drum & Bass tracks you will know that there are perfect to test subs for Extra low LFE and speed.
    I have also compaired them with a friends set up and he is running two passive 15in REL subs powered by mono Rotels (1200) and even though the Paradigms don't go as low they can keep up with speed. But boy the REL's go the lowest I've felt.
    Samir
    Can't wait to add my second PS 1000 that when things start to get interesting!
