Budget Starter System?
Discussion in 'Home Cinema Speakers' started by james4001, Dec 14, 2003.
  1. james4001
    james4001
    Dec 14, 2003
    43
    11
    I am new to home cinema and buying on a budget. i am considering the Sony STRDB790 reciever for £226 as it is 6.1 compatable and i have found a speaker package for £230 consisting of MX3-M(Front Speakers), MX1-M(Rear Speakers) and MXC-M (Centre Speaker). Is this a good system and do you think i need a subwoofer. Any comments would be grateful, thanks James
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    This package seems to be excellent value for money. You don't need a subwoofer with it but that doesn't mean that the overall sound wouldn't benefit from having a decent sub as it would.
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    I used to have Tannoys for my 5.1 system & they were excellent value for money. My only concern is that the Sony may not be up to driving the MX3s (my old Sony amp seemed to have trouble with MX2s) - I haven't seen the amp so I may be causing a completely false alarm, might be worth asking a few Questions though.
    Of course if you are buying mail order, it's not an issue really as you can return anything within 7 days under the distance selling regulations.
  4. james4001
    james4001
    Dec 14, 2003
    43
    11
    Thanks guys i have looked at subwoofres and i am considering a yamaha YSTSW215, and i think that the sony STRDB790 reciever is rated at 6x100W so should that be enough for the tannoys?
  5. james4001
    james4001
    Dec 14, 2003
    43
    11
    Im sorry if i am nagging people but i realy need advice on buying a home cinema system as im new into this sort of thing
    James
