tenohfive
Established Member
I've decided to fill in the blanks in some of the music-less rooms in my house for when playing multiroom audio whilst doing stuff. So I've picked up an old Yamaha DSP-E492 (30wpc) that'll do two different zones.
One room is the kitchen and - scorn away - I'm planning on using whatever cheap used centre speaker I can find to fit above the kitchen units or on a windowsill. It's not a big room and I just want to be able to hear music when passing through it.
The second room however I will spend a little time in. It's 4x3m and the joys of having to kid-proof everything mean that the speakers will be in a corner, unless I wall mount them. So I'm looking for something fairly forgiving. With a tight budget I'm not expecting anything life changing but as ever I'd like the best I can afford.
I've got a budget of around £100-120 so I was thinking a cheap of pair of Q3020's if bought new or swing for the cheapest Dali's I can find used. Any gaping holes in my plan here, or something that'd be better suited?
