budget recommendations
Discussion in 'Projectors, Screens & Video Processors' started by jGrahamD, Sep 11, 2003.
  1. jGrahamD
    jGrahamD
    Feb 11, 2002
    259
    Any recommendations for a budget projector? I just missed the £660 PT-AE100E at Komplett.
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    You could go for the AE200 for £753 at Komplett or is £660 your absolute maximum
  3. jGrahamD
    jGrahamD
    Feb 11, 2002
    259
    Thanks for the reply, that's a possibility. I'm not in any great hurry, will probably buy between now and Christmas. The budget is flexible if I can find a really great projector.
  4. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    Could be worth holding out then until the Z2 & AE500 come out. At least if you do not go for one of those models the older models may come down a bit i.e the AE300 may be sub £1k in a month or two :D
  5. jGrahamD
    jGrahamD
    Feb 11, 2002
    259
    I like the sound of the Z2, but it will probably be over my budget, unless I wait for the Z3....
  6. SanPedro
    SanPedro
    Jan 11, 2001
    4,503
    +504
    This is like waiting for computers to go down in price and up in spec.
    There's never a right moment ;)
    If you have the cash, buy one now and start enjoying it. I have an AE100 and I still thing its the mutts nuts. Even though i know there are better models out there.
    Whatever you buy, you'll buy at the wrong time. Trust me, I've bought enough computers overe the years. ;)
    cheers
    Chris
  7. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    The Z2's specs seem spot on for just about everybody's budget-ish needs.
    Question: Does the AE200 have the RGB Scart input like the AE300???
