Budget Projector
Discussion in 'Projectors, Screens & Video Processors' started by samwilliams, May 15, 2001.
  1. samwilliams
    samwilliams
    Hello.
    I know nothing at all about projectors, but i'm looking for one! What i want it for is to watch films, TV and use with my playstation. I'm looking at options under about £1700, the cheaper the better. I was also wondering, how well do projectors work with a reasonable anount of light on. Thanks for all your help, because i know nothing!!
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,535
    Newcastle
    +327
    The Sanyo PLV30, NEC VT540, Mitsibushi MT1 are around £2000 (IIRC - actually, you'd better check the prices for the NEC and Mits).
    Also, the following threads may be of use to you:
    http://www.wvip.co.uk/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=000476 http://www.wvip.co.uk/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=000474 http://www.wvip.co.uk/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=000455
    I've only seen the Sanyo out of these 3 and it looked fine in a room with a large window at lunchtime on an overcast day in Winter (i.e. moderate ambient light).
    Cheers,
    Liam
    [ 16-05-2001: Message edited by: lmccauley ]
  3. RMCF
    RMCF
    Aug 24, 2000
    7,509
    +774
    If you're looking to get hold of one at a reasonable price I would advise you to keep checking on the auction sites such as www.ebay.co.uk or www.yahoo.co.uk, as they usually have the odd one available.
