Budget projector
Discussion in 'Projectors, Screens & Video Processors' started by alpeag, Dec 12, 2003.
  1. alpeag
    alpeag
    Nov 11, 2003
    24
    Dublin
    hello there to everyone at the forum, as u can see i'm new to this and i would like some advice on buying projector
    Max price approx £1500 (excl screen) and the ability to project an image on a 6ft screen from 15 ft away.
    I have no experience with this, so any help would be appreciated, cheers.
  2. Georgio
    Georgio
    That's a rather long throw. Most home cinema projectors have a short throw/wide angle lens that won't throw a picture that small from such a distance. One exception is the inFocus X1, which can be had for under £800 and is very good value as long you are immune to the DLP 'rainbow effect' that some suffer from.
    For more information on the throw of various pjs, go to:
    http://www.projectorcentral.com/projection-calculator.cfm
    You should be able to use the calculator there to get a list of pjs that would suit your setup.
    Georgio
  3. alpeag
    alpeag
    Nov 11, 2003
    24
    Dublin
    cheers for the reply. lights rule out ceiling mount, and other half rules out it going in a cabinet on the floor
  4. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    If you plump for a DLP projector, you must demo it first to check for your susceptibility to rainbows.
    Check out this link (from Sean G's Projector FAQ in this forum). Does my head in...
    Joel
  5. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    I use my AE200 on a small coffee table and then put it back in it's case after use to keep it all wife friendly. Could you not do the same?
  6. groovedigger
    groovedigger
    Nov 11, 2003
    28
    3
    Brighton
    Nexnix in Horsham will do you an exceleent DLP PJ - the Sharp-XV-Z91E - for £1500 inc free prog scan dvd player at the mo. I can recommend the PJ, and they'll also do you a deal on a screen if you don't want the dvd... hey and guess what - my wife's happy with it!!
    http://www.shootandshow.co.uk/sharp-XV-Z91E.htm
  7. joe davis
    joe davis
  8. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Thats an old fashioned 1500 quid tho:eek:
  9. alpeag
    alpeag
    Nov 11, 2003
    24
    Dublin
    cheers for the ideas and advice, most appreciated.
    Hopefully the end result will keep the home a happy one
  10. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,475
    Surrey. UK.
    +2,119
