budget prog scan player advice please
R
robwight
Im waiting on delivery of a tosh 57wh36 rear pro tele that has pal prog component inputs,just bought a denon av amp , have the speakers , all i need now is a good pal prog scan dvd player for under 150,about 100 would be great.
having a quick look the yammy s540 looks pretty good for 100 smackaroonies
any other dvd players you guys can suggest ? ( pref black too.. )
most dvd's i own are pal.
thanks ..
jurass
consider Sony 730. it has a much better deinterlacer than Yamaha. check both tested here . unfortunately in German. lower values are better.
R
robwight
any other recommendations ? , special offers you guys have seen ?
hornydragon
HK DVD2550 £250, Denon 2800 were cheap a while ago but had a few issues,
Depends if you want PAL Prog? HK does but Panny S75 is NTSC PS and Interlaced PAL also plays Ram discs if you are considering a DVD recorder.
Contar
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
