Budget Pro Logic 2 Amp?
Discussion in 'AV Receivers & Amplifiers' started by shez316, Mar 5, 2002.
  1. shez316
    shez316
    Feb 25, 2002
    117
    +3
    I looking to start up a home cinema system. I'm looking for an Amp and speakers within a budget of £500. I'm looking for 5.1, DTS and Prol Logic 2. What do you recommend?
  2. laurel
    laurel
    I would recommend you increase your budget :D
    Why not look at something like the Marantz SR4200 (around £250) + one of the mission 'packs' from Richer Sounds?
    The Mission Cinema 7 pack is good and well recommended but that runs around £400 - but hey - that only adds up to £650 and budgets are meant to be broken. :)
    Of course you will then need a sub.:eek:
    Welcome to the world of "empty" bank accounts.
    Laurel
