Budget Home Cinema £500
sm0akes
I was thinking a Marantz sr4400 reciever but i am a bit lost on speakers.
Is the marantz a decent amp? What would you buy?
hornydragon
4400 is ok MS premiere speakers go well but look at canto CD1 and Tannoy FX5.1 as well as yamaha denon and Pioneer amps
paulus
I would consider going for the SR5400 which is only an extra £50 but will sound even better than the SR4400. Richer Sounds do the 5400 for £300 which leaves you £200 for speakers. You could get 5 reasonable speakers for that but you might want get a good set of fronts and a centre for £200 and add a set of rears in a couple of months when you have saved some more dosh.
I used to have a SR4300 (which was good) and swapped it for a SR5300 but I was surprised how better it sounded.
bjd
