budget freeview with RF modulator needed
Discussion in 'Freeview & YouView' started by waz2004, Apr 12, 2005.
  1. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    i am sure this has been asked before but i cannot find any reviews etc
    what i need is a good quality freeview with two scarts. It must have RF modulator (i think that is what it is called) which allows freeview programs on non-scart TV.
    Have been made redundant a while back and am in the process of cancelling NTL digital to cut costs. Looking for a decent freeview to continue receiving CBBC etc for the kids
    curry and dixons don't know left from right.
    my search has found humax f2-fox-t but it is expensive
    anyone know anything about mitsubishi BD65 from richer sounds?
    any advice and supplier appreciated
    thanks in advance
  2. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    I too am after a budget box with an RF modulator, i posted the same question a day or so ago and have had no replies so good luck!
    I posted a few minutes ago about the Sagem ITD64 which some sites list as having a modulator but others don't! waiting for replies to that one.
    Good luck? Looks like we need it
  3. JimmyGrimble
    JimmyGrimble
    have you not got a crummy old vcr you can route the rf through?
    thats what I am doing at the mo.
    the vcr is hiding in the drawer of my telly stand cos it has a busted fascia
  4. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
  5. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    So if i connect the STB scart to the vcr it will loop through the vcr rf output to my TV? If this is correct can you do this with a DVD player also?
  6. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    jimmy - the freeview will reside in the back room and will connect to the tv through scart. for the tv in the front room i need RF connection. the other options i have is
    1. buy another cheap freeview for the front room, or
    2. buy a AV sender
    considering the cost of AV sender units it might be cheaper to go for option !
  7. JimmyGrimble
    JimmyGrimble
    to the Judge : yes to both in my case - can't guarantee your setup of course.
    it will be converting not looping,
    think all brands have loop through., but not many modulate :(
    maybe borrow an stb to try?
    to Waz : is it time to buy a new telly with scarts ;)
    seen freeview boxes for £30 now so not much to lay out anyway
  8. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    jimmy - original plan is to buy a good freeview. run a scart to back tv. The other tv in the front room is too far away for a scart lead therefore the need to connect it using a standard aerial cable. Then again i could go for option 1 and buy two freeviews with RF loopthrough. Any recommendations?
  9. JimmyGrimble
    JimmyGrimble
    2 cheap freeviews @ £60 total =sorted.
    To have 2 boxes has got to be the way surely, so people can watch or record different programmes on at the same time. search on the forums for recommended gear -plenty at richersounds trade counters and tescos, argos etc. I only have experience of two makes.
    hope we have not got our wires crossed heh, but if your front tv has no scarts or s-videos you will only get the 5 analogue channels out of the STB via your roof aerial; loop through just passes this on after its been in and out the freeview box.
  10. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    jimmy-both tv has scart. as a matter of intrest you said you have experience of two makes. which ones and your opinions please
  11. JimmyGrimble
    JimmyGrimble
    pioneer dbrtf100 decent enough box cept for that distracting 3" long light that is red or green on the front. and it failed after 6 days.
    didn't want another so got a JVC one instead which is excellent now it has the latest software in it. very quick to respond to channel changing or aspect ratio changing. the 7 day EPG sometimes only has 3 or 4 days info but this may be down to the reception area or even the person typing up the info!
    vestel based but a good box. slim n stylish too. both are £70ish which don't help as you must be short of cash now redundant.
    bin there 3 times m8
    keep yer pecker up
  12. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    thanks jimmy i will surely keep it up.
