Budget Freeview STB Recommendation
Discussion in 'Freeview & YouView' started by 77KWC, Apr 2, 2007.
  1. 77KWC
    77KWC
    Mar 29, 2007
    49
    11
    Warks
    +3
    Hello people,
    I need a new Freeview STB for my new Hannspree screen I purchased last week. Which are the popular, cheap and cheerful ones you people recommend? I only need the very basic version which is at least software upgradable (is it necessary?) with no needs for programme recording and/or Topup TV slot. Thanks in advance. :D
    Regards,
    Terry
  2. Naqv
    Naqv
    Oct 15, 2006
    3,651
    Birmingham
    +355
    A basic £19.99 would do.
    Search online or go to Teso/Asda etc.
    I am sure that i saw one for eith £19.99 or £24.99
  3. 77KWC
    77KWC
    Mar 29, 2007
    49
    11
    Warks
    +3
    Thanks.:thumbsup:
  4. KenMavor
    KenMavor
    May 2, 2005
    36
    +6
    Just bought a Durabrand digital set top box for £19.99 from Asda and it works well. Would recommend going for one with a hard drive inside it so you can record programmes as well.
  5. 77KWC
    77KWC
    Mar 29, 2007
    49
    11
    Warks
    +3
    Thanks. My uncle gave me an unused Nokia OnDigital Freeview box from 2 years ago when his TV set didn't have Freeview built-in. It works beautifully at no cost! :smashin: Great
