Budget DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by RichieRich, May 6, 2001.
  1. RichieRich
    RichieRich
    I'm thinking of buying a Wharfedale M5, does
    anyone have any experience of this player
    or can you recommend an alternative?
    RichieRich
  2. fishyben
    fishyben
    If you want a budget player there are better ones out, eg Samsung 511 for as little as £149 online
  3. Guest
    Hi RichieRich,
    We got the M5 a few weeks ago. The machine has similar features to our old Xwave lb900 but overall is superior to the Xwave lb900. Known problems to date are few. There is a layer change problem and the picture can freeze periodically.
    As for cheaper/better machines online. We have had one too many bad experiences of dodgy dealers online. If I can't buy it from a shop or if the online supplier does not have a high street outlet then I don't want to know!
