budget dvd ram player
Discussion in 'Blu-ray & DVD Players & Recorders' started by sonynut, Dec 1, 2004.
  1. sonynut
    sonynut
    waiting for delivery of my panasonic e55, so now i am looking for a budget dvd player that will read dvd ram discs for bedroom anybody got any suggestions THANKS
  2. gozo1
    gozo1
    Jan 11, 2005
    14
    Sonynut. I'm in a similar position. Did you find a player?
  3. Adebenchris
    Adebenchris
    Richer Sounds are selling the Panasonic S27 for £39.99 - gets a great write up in the reviews ( Home Cinema Choice June 2004) and will play RAM discs. If you want it multi region you can get it altered by dvdchips.co.uk ( I think this is about £20 quid) Hope this helps. :)
