budget dvd player...
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mr Cat, Jan 27, 2005.
  1. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    hi, my girlfriends dad wants a budget dvd player...
    it must be able to play copied dvds, mp3 etc...whats the best one..?
    I would say the Toshiba SD340E as his budget is around 70 quid...
    any others that I should check..?
    it will just be plugged into a bog standard tv - and using the speakers from that for it's sound
  2. MSYam
    MSYam
    Jan 6, 2005
    95
    It sounds to me like even the Tosk 240 would be good enough. You will pick one up for about £40!
  3. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    there is also this one too - Philips DVP 630 DivX Multi Region Capable DVD Player
    seem a fine player too...
  4. aligamer
    aligamer
    Feb 4, 2004
    88
    9
    United Blighty
    Andon't forget H&B's divx dvd player the 3255, vga output, prog-scan and subtitles etc and under £70! - best budget player thus far! (and multi-region) :laugh:
  5. steve69
    steve69
    Apr 15, 2006
    582
    shropshire
    +45
    yeh the h&b i just ordered for £29 so cant b bad at that price if it plays\everything it says it does.
