I am Jon
Established Member
Looking to redecorate living room where my AV setup is. Unfortunately it shares one wall with neighbours living room. Since I can hear their kids and TV at times i'm sure they can hear my system too but never had any complaints. I do try to keep the volume reasonable with the sub toned down and in the opposite corner.
Think the chimney itself being several layers of brick and air isn't too bad. Would covering the joining wall in just the alcoves with some acoustic board make much difference?
Looking at something like this: ProSound SoundBoard 4 (1.44m2) 30mm. Total area would only be 3m x 2.4m, so £350 should do it. Can I just apply direct to the walls? Is it ok to paint over this stuff or does it need plastering over?
