Budget Component Cable Recommendation
Discussion in 'Cables & Switches' started by ahaydock, Feb 10, 2009.
  1. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    I am after a Component Video cable to connect Sky HD to my Panny 50PX60. In the past I have used, and am a fan of QED and Ixos cables, however I am on a tight budget of around £20.
    Can anyone recommend some decent cables at this price?
    I have found these:
    This seems like a good one and it’s close to budget: Qed Qunex P-CV1 Component video cable - From £21.50 - HiFiCables.co.uk
    [​IMG]Ixos XHV204 Componant Video I/C
    Ixos XHV704 Component Cable - From £34.21 - Hi-fi Cables Direct Ltd (a bit over budget TBH)
    Also will I see much difference in PQ between using one of these cheaper cable compared to HDMI?
    TIA.
  2. steford
    steford
    Mar 7, 2004
    1,238
    48
    Ealing
    +62
    Tech+Link are an excellent cheaper alternative. I have one spare if you want it - over in the classifieds.
  3. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Do you have a link as I couldn't find it?
    How does it compare to the QED cable I've listed 1st?
  4. steford
    steford
    Mar 7, 2004
    1,238
    48
    Ealing
    +62
  5. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Thanks.
    Anybody else have any thoughts...
