Budget Case
Hey I'm currently looking for a budget ATX tower case, Ideally spend under £40, and to include 3/4 5.25drives, and a 3.5, space for 2 hdds, In black, and relatively nice to look at, and be able to keep the noise in, with a good amount of space for airflow.
I had a look in maplin earlier and only one interested me, but it would have been getting it for the sake of it, because I got a bit fedup looking online, and not having a clue. If somebody would be kind enough to help me - preferably if you have/have had the case you suggest, would be appreciated.
tinners
CoolerMaster Centurion 5 ~ £37.01
Review here
Score 9/10
Pros
Cheap
Stylish
Quiet fans
Excellent drive mounting mechanism
Screw-free AGP and PCI card retention mechanism
Cons
No removable motherboard tray
Not the coolest internal temps I've ever seen
enablerbro1
Centurion's a nice case, I have one, pretty roomy and well laid out. The screw free retention mechanism isn't the best over time, unless they've redesigned it as mine is a few years old, but a pretty good case none the less.
amjedm
What was wrong with the Zen?
Flimsy/cheap side panels.
Front air intake is almost non existant.
Not possible to remove front top 5.25 cover.
Only positive point was it included two 120mm fans - still had to undervolt them IIRC.
I've built systems in the Antec SLK3000B and much better construction IMO.
