Budget AV receiver options for 2.1
Fledermaus
I recently got my old Nad 310 out from the cupboard, bought some Q Acoustic Concept 20 speakers to replace my old JPWs, and I bought a used BK Gemini, and an Arylic S10 so I could stream from my phone - the main way in which I now listen to music.
However, the only way to connect my TV (LG CX 55) to the amp is a 3.5mm output to RCA. I am sure that a digital output would be better. Being able to control the amp with a remote would also be good, and I would like an amp with a dedicated crossover to separate the output to the speakers from the output to the sub. Which leads me to an AV receiver - I think. I don't want to spend much, and I am not interested in 5.1 performance, etc. I would probably be using the receiver as a 2.1 amp, with an output from the TV. I also want a receiver that has built-in Bluetooth and preferably wireless connectivity.
I've found the following, all going pretty cheaply (max £120):
Sony STR-DN1050
Yamaha RX-V479
Yamaha RX-V567
Are any of these way better (or worse) than the others? Any other suggestions? Or, for my limited purposes, am I beating up the wrong bush?
Thanks.
dobrykamil
Definitely go for str-dn1050.It’s a superb amp with really good sound.
Fledermaus
Thanks. I have looked at the comparative reviews for all 3 again and it does look like the Sony is the best option. Trigger pulled!
Fledermaus
I received it last night (seller from these forums lives very locally and kindly delivered it). I quickly set it up and it sounds AMAZING. Especially for £80! It feels like a remarkable bargain.
LG C1 OLED TV Best Picture Settings for SDR, HDR and Dolby Vision
