Budget amplifier recommendation
Discussion in 'AV Receivers & Amplifiers' started by welly123, Dec 27, 2006.
  1. welly123
    welly123
    I used to have a Denon 500SD system but unfortunately it went bang :(
    Now I'm left with the 5 surround sound speakers and a passive subwoofer and nothing to drive them with. Can anyone recommend an amplifier at the lower end of the market that would be suitable for use with this setup?
    Probably going to get Toshiba 360E/Samsung HD860/Sony DVP-NS76H DVD to go with this, if that helps.
  2. welly123
    welly123
    Would the answer to my question be get an active sub?
