Question Budget Amplifier For 5.0 or 7.0 Setup
Discussion in 'AV Receivers & Amplifiers' started by bluezedd, Jan 13, 2017.
  1. bluezedd
    bluezedd
    Dec 27, 2016
    10
    glasgow
    Hi guys,
    I currently have these speakers, but no amplifier (apart from a yamaha 2 channel stereo one) to power them. I have held off getting an amplifier, as I was wanting to hold off and get speakers which have been discontinued, to match the ones I already had.
    2x Wharfedale Diamond 10.4
    1x Wharfedale Diamond 10.CS
    2x Wharfedale Diamond 10.1
    2.x Wharfedale WH-2 Surround
    The room I am using the setup in is relatively small. I have 7 speakers, so could have 7 attached to the amp. I didn't get 7 speakers intentionally for a 7.0 setup. I already had the 10.1s for stereo use. i could set them all up though.
    My question is whether you think I should purchase a new, or second hand amplifier. I am on a low budget. My ideal cost would be £250, but I could potentially stretch to £400 for the DENON
    AVRX2300W, as I know that's last years winner in this price category.
    I also saw the Denon AVRX1300W for £300, which is less of a sting for me to buy. :p
    I am relatively frugal, so wouldn't want to spend a massive amount of money if I don't need to (for me £400 is a lot of money). Then again, I'd rather spend a bit more and have an amp that will last me longer.
    Let me know what you guys suggest I go for. I also like yamaha amps. :)
    I will likely get a sub at some point too.
    Thank you for any help :)
  2. gibbsy
    gibbsy
    May 17, 2007
    13,135
    3
    Cwm Cynon, De Cymru
    +7,249
    You've answered your own question. Denon X2300.
  3. bluezedd
    bluezedd
    Dec 27, 2016
    10
    glasgow
    Thanks for your reply gibbsy. Do you think the X2300 is worth the extra, compared to the X1300?
    Many Thanks.
  4. Big Shoes
    Big Shoes
    Dec 4, 2008
    52
    11
    +8
    Yes
  5. gibbsy
    gibbsy
    May 17, 2007
    13,135
    3
    Cwm Cynon, De Cymru
    +7,249
    Without doubt.
  6. bluezedd
    bluezedd
    Dec 27, 2016
    10
    glasgow
    Ah ok, thanks guys! It looks like im just going to go for it, and get the x2300. :D
    EDIT: aww it was out of stock :(.
