Budget Amp suggestions
Discussion in 'AV Receivers & Amplifiers' started by BiggieBig, Jan 17, 2004.
  1. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    hi guys,
    I'm trying to up grade from my yammy HTR-5550. Want better sound quality and more dynamics.
    Brought the Marantz SR5400 thinking it would do the trick but i'm a little disappoined not much better then the yammy. My wife thinks it sounds worse so it must be really bad.......
    Gonna return it tomorrow.....
    so i'm in the market for an amp..... heres my spec
    I have Celestion AVP305 (8ohm Satalite speakers)
    Budget around £350 (must be silver)
    Preference (Good quality music in 5ch mode)
    Considering....
    Denon 1804 ....
    Will this be any better .....
    Any other suggestions out there.......
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Might I suggest that you give the Marantz receiver a few weeks to 'Run In'.
    It's commonly accepted that receivers have to be given plenty of use when they're bought 'from new' before they begin to sound anything like their best.
    The Marantz SR5400 is a very good receiver and amongst the best in its price bracket, and for sound quality (especially with music) should significantly outperform the Denon you mention.
  3. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    hi Dimmy,
    Thanks for the advice,
    maybe I made it sound worse then it is, it's not that the reciever sounds really bad it's just that i'm missing some detail that was present with my old yammy.......
    I know speakers need run-in time but I never realised amps do...
    ok I have 2 weeks to test the amp if there's no improvement it'll have to go back.....
    I've also noticed from other threads that your definitly a marantz fan.....
    in the mean time any other suggestions from anyone else......
    Dennon,Nad,HK etc etc
  4. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    I think the pioneer VX812 might suit your budget quite nicely. You could also look at something second hand, as that could push the price/performance barrier even higher.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Have a look at the HK AVR505 see if you can get a demo, also the HKAVR2550 or 3550 latter is over budget, these are quality amps akin to the denon but a bit different and well worth a demo mate.
  6. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    i've got a demo @ seven oaks next Saturday....
    Marantz SR5400 (for comparison)
    Denon 1804
    Pioneer VSXD812
    HornyDragon
    Is the HK AVR505 \ HK AVR2550
    available in Silver :-
    might ask seven oaks to add these to the demo list,
    but 4 amps to demo might be talking the p.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  8. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    thanks,
    A little confused is the AVR505 LE a silver equivalent it just that it's half black. Are they available in all silver.
    I guess that applies only to the 2550 & 3550 as the rest will be out of budget.....
    Also how would they compare to the Denon and Marantz for music quality....
    Also should I consider NAD
  9. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    just seen the
    Harman Kardon AVR2550 for £270 in silver.
    It's a clearence... And may go soon...
    Also is this an old reciever now.. I know it's good for it's time but can it still be compared to the latest models with the latest tech...
    i.e (marantz 5400 Denon 1804)
    A few websites say it's discontined and one says it won what hifi receiver of the year award 2003
    so i'm thinking of just purchasing without demo... And go on forum advice that HK are brilliant sound quality...
    Will it beat Marantz and Denon for sound quality I don't care much about power...
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Marantz I think so denon clsoe call. Build quality almost certain to be better than marantz, HK are quality not bells and whistles latsest gadgetry type units. The 505, 507 limited editions are a stop gap for a new range that is out in the US and will be in Europe soon ish £270 is a very good price if the unit is brand new boxed, not an Ex demo unit.
  11. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    If you are happy with 5channel amp, then yes, NAD and HK are the best in terms of musical quality, definitely one to two levels up from those I mentioned yesterday.
    NAD T742
    http://www.nadelectronics.com/reviews/T742_T512-1203.html
    http://www.nadelectronics.com/reviews/T742_512_0803.html
    355squids at for titanium at http://www.hifi4less.com/NAD_T_742_AV_Receiver.htm
    HK AVR-3550 new unit-397squids at
    http://www.edge-sv.co.uk/offers.phtml?sortby=offerprice&order=desc
    I reckon, NAD has the edge in terms of 2-channel music as it is their primary market for decades. I have had a NAD 320 looooong time ago in Sweden, my first amp, so sweet and dynamic, matching a pair of JBL LX55 3-ways, I think, and it was no problems driving them.
    Anyway, none of them 2 are a bad choice.
    Wasabi
  12. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    Just borrowed my brothers HK AVR 507 and it blew me
    away sounding amazing so crystal clear so HK it is.....
    thanks guys for leading me in the right direction.......
    wasabi do you know if this is the silver or black... is the silver available in AVR 3550
    or I may just order the AVR 2550 (silver one) I know it's not as good as the AVR 507 but do you guys know if it will still be crystal clear and clean...
    once again thanks guys
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    There is the AVR 505 mate
    better spec than 2550 and silver ish
  14. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    do you know what price range and where I could get hold of one
    what do you mean by silverish ?
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    2 tone same as 2550 and 507 (for HK that is silver) erm try an HK dealer Sevenoaks, AV-sales, Hifibitz and others but local dealer is best bet matey (where did your bro get his???)
  16. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    panny shop in a local store in London might give them a ring to see what they have
  17. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    ok wife doesn't really like the HK cos it doesn't go with the decor.....
    Maybe the NAD T-742 does any one know how this sounds in comparison to the HK's will it be just as good
  18. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    hi does any one know here I can get hold of the NAD T743
    the titanuim colour
  19. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Have you considered the Yamaha DSP-AX640SE? Always comes out well in mags group tests and available for £280 at RS.
  20. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    hi guys,
    got a HK2550, at a good price (£270) but sent it back.
    Sounded good with a lot of detail but was a little bassy
    May not be fair to make a comparison but it beat the following hands down IMO:-
    Marantz SR5400
    Yammy HTR 5550
    Went way over budget and got a HK AVP507 sounds
    just superb. Detail amazes me each time I switch it on:-
    THANKS FOR ALL YOUR HELP GUYS
    :clap: :clap: :clap: :smashin: :smashin: :clap: :clap: :clap:
  21. Spy
    Spy
    Jan 6, 2004
    3,140
    London
    +267
    Depsi,
    Where did you get the HK 507 from ?
    Was it the same place as the 2550, if not where was that from ?
    Regards,
    Spy
  22. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Never found out what speakers you were using! I bet that 2550 will be £250 now!
    Glad you like the 507, does the missus think it sounds better than the marantz?
  23. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    I'm using the celestion AVP 305 speakers.
    and a Panny DMR- E50 recorder
    (this amp is probably an over kill for these speakers but it does bring out the best in them)
    Missus can even tell, she wasn't even into all this. But after I started trying various amps and speakers she was forced to hear the differences.
    She didn't like the sound of the Marantz, and now she thinks the HK sounds great.
  24. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Superb mate keeping everyone happy is the name of the game, Celestions can be a buggger to drive, which might be why you found such a difference.
  25. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    Spy,
    hifibitz.co.uk are doing the 2550 Silver version for £270.
  26. Spy
    Spy
    Jan 6, 2004
    3,140
    London
    +267
    depsi,
    How much did you pick up the 507 for ?
  27. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
    507 was from a local retailer in North London.
    I got it for £470 (but that was a special deal because my bros brought a fair bit of kit from them)
    Can get it fro £477 from the link given by wasabi in this thread.
    I gave them a ring and they said they would include delivery for that price.
  28. stevieby
    stevieby
    Dec 11, 2003
    274
    +7
    hi depsi
    which link was that as now want to get one today but phoned up one company and now out of stock!!!
  29. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,293
    48
    London
    +27
  30. stevieby
    stevieby
    Dec 11, 2003
    274
    +7
    thanks, already rang them and they said out of stock.
    Trying another website for 480 and hopefully will get one for saturday.
