Budget Amp and Speakers for Movie & Music
Discussion in 'AV Receivers & Amplifiers' started by spib, Jun 9, 2004.
  1. spib
    spib
    Jun 3, 2004
    58
    11
    Hey Guys,
    I'm looking to buy an amp (maybe w/ receiver) and speaker package. The speakers I'm looking at the moment are the Mordaunt Short Premier Plus system. Is there anything better for a similar price? I'd like the system to double as a music system (insofar as I'll be playing MP3s through them from a Media Centre PC/CDs through my DVD player).
    As regards amps, I'm open to suggestions. I was interested in Yamaha but I'm told they're not to good at music. I've heard Denon are quite good in thi price range?
    My budget is max £650.
    Any advice would be greatly appreciated.
    James
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,200
    2
    +3,674
    It seems that once a manufacturer has a reputation for doing something well or something badly, it sticks no matter what. Yamaha amps used to be pretty woolly in stereo (and they still aren't the class leaders) but they really have come on since then- I don't think you'd be dissapointed with them. The most musical amps at this point are probably still the Marantz units but they are less user friendly and less downright loud than their Denon and Yamaha rivals. The Denon stuff seems to be consistently good but personal preferance would lean toward the Yamaha's with the Premieres or (going on other recomendations) the Harmon Kardon range. Marantz (our distributor let us not forget) really don't get competitive until the SR7400 which is a bit more.
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  4. spib
    spib
    Jun 3, 2004
    58
    11
    Thanks for the replies so far. Sorry I wasn't clear before, the £650 is for an amp and speakers.
  5. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  6. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The Aego system may not be suitable if he wants something he can upgrade easily.
    I took a look at the back of the unit and there are no speaker terminals apart from co-ax outputs, which suggests to me that the processing is done in the little box, and the amplification is taken care of by the sub, similar to how the Digitheatre DTS used to work from Videologic.
    So upgrades will be difficult.
    I think a Yammy 640 and the Mordaunt Short premier package at peter tyson would be the way to go
  7. spib
    spib
    Jun 3, 2004
    58
    11
    That's correct, I want the amp to be a standalone unit to allow for future upgrades etc.
    So the Yamaha RXV640RDS is a possibility. What do you guys think of the Denon AVR-1804 or the Marantz SR5400? Is the Marantz SR5400OSE worth the extra cash?
    Cheers for the help so far
  8. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    I've got the 1804. I auditioned it alongside the Yam 640, and to my ears, there was very little difference when playing a movie, but the 1804 sounded a lot better for music playback. This was with a set of Kef Eggs.
    I'm very happy with my 1804.
    Balders.
  9. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    I've got the Denon 1804 (£277 inc) and the Premiere Plus (£325inc). Not had too much time to play, but I lkie the sound more & more each time I listen. I upgraded from a Yammy amp & cheap Eltax speakers. I would say the Denon is 'warmer' in sound to the Yamaha it replaced.
    I'm still tinkering with the setup of the Ms309 sub - needs careful integration to avoid being overblown with bass.
