OutOftheLoop
Hi all,
I hope you're all well and safe. Thanks for all the knowledge that's being shared on this forum.
I'm on the hunt for a budget 43inch TV for a friend and holding out until Black Friday to make the purchase. Budget is approximately £300.
1. HISENSE 43A7100FTUK - £299 now (no reviews, should be a VA panel)
2. SAMSUNG UE43TU7100 - £350 now but hoping for a Black Friday Reduction (has great reviews, especially on upscaling, unknown panel type)
3. Philips 43PUS7555 - £350 now but hoping for a Black Friday Reduction (some good reviews, unknown Panel type)
Is anyone of these significantly better than the other? Or Is there any TV that I am overlooking that should be in this list?
Thanks all!
- It's for a new (small) flat that already has a built-in TV cabinet/bookshelf that only fits a max 43inch screen.
- The couch will be about 1.5 metres (5ft) away and mostly viewed head-on.
- Viewing habits will be almost entirely HD and UHD streaming (90% netflix/prime/youtube - 10% BT Sports/ BBC Iplayer) - no terrestrial tv
- Mostly viewing in the evening and weekends so will be a dark room most of the time.
- In terms of motion handling, I have seen TVs with blurry motion which are unwatchable. I currently have the Hisense 55 NU8700 (VA Panel) and have switched off all motion handling and we can comfortably watch action movies and sports, so am looking for something with similar abilities with regards to motion.
- Would like a solid after-sales experiences with a good warranty, so I think that limits me to John Lewis and Richer Sounds (which rules out the TCL TVs)
- Also considering adding a roku streambar in the future to take care of sounds and platform so the TV needs HMDI ARC compatibility (I think that's how it works)
Thanks all!
