Budget 39/40 inch TV
waterman6
Hi, I'm hoping for some advice please. My TV has just given up the ghost and I'm looking for another one - either 39 or 40 inch.
I've already got a Amazon Fire TV stick so I'm not that bothered about smart features. And I've also got a Freeview Plus HD box that I'm happy with so I'm not that bothered about Freeview Play either.
I enjoy watching sport so a tv with decent motion would be good. I'm looking to spend up to £370.
Thanks for any advice.
Dodgexander
If you are size limited to 40" you have basically one option; the Panasonic 40HX800. That is unless you're happy going for a HD TV.
These don't start to appear until you reach 48/49" in size and a lot more expensive. Smaller TVs now are bottom of the range models.
waterman6
The reason I wanted a 39/40 inch tv is because my sofa is roughly only about 6ft (72inches) away from the TV. And I know you're supposed to divide that by 2 to get your recommended screen size - so that makes it roughly 36 inch tv. But it looks like I'll have to get a 43 inch tv as there are hardly any 39/40 inch ones.
Can you recommend any good 43 inch tvs?
Dodgexander
6ft is not really near to view a TV. 43" will be on the small side at that distance if you want to benefit from 4k as a resolution.
All recommended models are in my guide here: **New** My best value TVs, 2020-2021 Edition
You'll have to decide on a panel type first, before looking at specific models. Keeping the budget as low as possible and with a preference for better motion you may want to consider Philips/Sony TVs which may mean you have to go IPS.
