Italian Job
Established Member
are these any good?
I'm only having a tiny problem the bass being a bit too unclean/resonant when playing some specific tracks - definitely due to the speakers arrangement and room - but that's for a separate thread!
to be honest the conical rubber feet it came with do an excellent job at anchoring it, they very grippy!Not in your case, the surface area of the tripod tips is just too small.
You might use these to good effect if the tripod thingy is prone to slippage across the floor.
3M SELF- ADHESIVE RUBBER FEET ROUND CYLINDRICAL BUMPONS UK anti slip black | eBay
Black Self - Adhesive rubber feet. Flat and curved surface rubber ( silicone) pads. Wide range of uses.www.ebay.co.uk
they put a smile on my stupid face every time I turn them on, the soundstage is almost holographic, I can't believe my ears.I’m pleased you’re happy with the speakers. It’s always a bit dubious recommending something as much to do with personal taste as speakers.
But they do very much seem to do everything right
-- As an eBay Associate, AVForums earns from qualifying purchases --
