BTTF Trilogy
Discussion in 'Movie Forum' started by mistrip, Sep 20, 2004.
  1. mistrip
    mistrip
    Aug 16, 2002
    319
    UK
    +12
    Does anyone have a definitive answer as to whether or not the back to the future trilogy on sale in shops now (Region 2) is the corrected (V3 presumably) edition. I've held of buying this for ages now and a brief search on these forums left me a bit confused. Some replies seemed to indicate that the V3 release would be out in Oct 2003. If this is the case is there a way to tell from the packaging.
  2. Tomaso
    Tomaso
    The v3 versions of R2 is very hard to find..
    The R1 films were properly fixed in v2.
    The only online shop I know to have the R1 v2's is http://www.playusa.com
    Some R1 v2 boxes have a green sticker on them wich says 'remastered', but then again; some don't..
    The only way to be sure is to open the box and take a look at the discs..
    Disc 2 and 3 should be labeled v2 on the edge.
    There was never a problem with disc 1..
  3. stevethone
    stevethone
    Sep 18, 2004
    424
    +5
    I got my R1 V2s from dvdsoon.com.
  4. sk4nky
    sk4nky
    Aug 30, 2004
    138
    what was wrong with the R2 discs?
  5. Tomaso
    Tomaso
    In the first release, movie 2 and 3 were misframed (both R1 and R2).
    This is fixed in the v2's, but the R2 v2's has a problem with scenes beeing to dark.
  6. Tomaso
    Tomaso
    Forgot to mention; This only affects the widescreen versions.
    Faulty discs can be returned to Universal in exchange for the corrected ones.
  7. sk4nky
    sk4nky
    Aug 30, 2004
    138
    oh right, got bttf on order from play.com, currently "out of stock" --wonder if they'll give me a good version or not..
  8. arnoldma
    arnoldma
    Sep 4, 2004
    64
    i think i got the crappy ones, as i bought mine when they 1st came out... any1 know how to send it back? like a url with address or something? thanks.
  9. stevethone
    stevethone
    Sep 18, 2004
    424
    +5
    BTTF Framing Fiasco
    This page has information about the "Framing Fiasco" and contact details at the bottom of the page for replacements in most countries.
  10. arnoldma
    arnoldma
    Sep 4, 2004
    64
    thanks, i just called them the women said they r not answering there phones so ill call back later, thanks for the info though :)
  11. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Well, after waiting 5 months (!) - I have eventually received "corrected versions" for my Region 2 BTTF II & III.
    On the discs, it shows R1 (BTTF II) and R2 (BTTF III)....does anyone know whether this means the last film has the darkness/contrast issue rectified?
    Thanks.
