Guys, Have any of you lot sent back your Back to the Future set yet???? I'm looking to send mine back but just thought I'd ask how you've got on??? Did it take long etc???? Thanks Stace
Your right there isn't a recall for R2, but you can get them swapped for the version with correct ratios, if you ask. See this link http://www.totaldvd.net/frame.html?http://www.totaldvd.net/cgi-bin/displaynews.php?id=2744 Stace
TBH I ain't going to bother sending mine back even if there's a recall, I have seen the movies that many times in various formats on the TV, cinema and dvd I couldn't begin to tell what was missing or not.
The new discs will be in April to tell them apart i don't know but it might say on the cover correctly framed or something like that. By the way don't send your discs to Universal UK as they will only send them back just send them a letter telling your problem and they will send them out in April. I said i have not got a POP but they said that is ok. Call them at 08705900909
