Quantcast
BTicino MyHome bus: MH202 advanced scenario controller
m4rky_m4rk
Yes, I have rain, wind, light (bright and dark) sensors and associated limit switches by Schalk
Measuring relays - Schalk Steuerungstechnik GmbH.
GSW 3 - Schalk Steuerungstechnik GmbH
SL 1 - Schalk Steuerungstechnik GmbH
GSL 1 - Schalk Steuerungstechnik GmbH
SR 1 - Schalk Steuerungstechnik GmbH
GSR 2 - Schalk Steuerungstechnik GmbH
There are also other manufactures of similar sensors and limit relays.
I am happy with the Schalk sensors. They have been very good and reliable. I have been impressed with the rain sensor. Its very sensitive to rain with even a few a drops triggering it and its been quick to dry off again when the rain stops. I have not had any issues with dew/fog causing a false detections.
These sensors do not output a measurement value but switch a relay when a preset threshold is crossed for a user defined time. So, to connect them to the BUS you will also need a BTicino Basic Contact interface. This changes state dependent on the relay state, open or closed. The contact state can then be used by the MH202 scenario controller. The Screen10 can display the contact state on the panel and there are some other things you could do to visualise and test sensor information and actions. If you want to know more just ask.
If you want to see the actual values then there has been some discussions about how to do that on the BUS by djtom2002 and others, here and over at BTIcino, before they became unfriendly. PM him if you want to now the latest but please bring the conversation back here so we can all share the discussion. I am interested. There is talk of a new driver/gateway being available but little discussion so far. Tom has been talking about it for while. Maybe he bought one?
I also have some inexpensive independent sensors (weather station, and many temperature humidity sensors) by Mobile Alerts that can display charts and graphs on a mobile phone, browser etc, send emails and warnings. I use these for cross checking and alerts. The Schalk sensors agree with these independent sensors. eg if I get an email for high winds then I also usually find the Schalk sensor has also activated the scenario to retract all the blinds.
I also have an BTicino wireless external probe. This does allow for actual temperature values to be seen and used on the BUS like a room probe would.
Did you get your lamp scenario working?
Tony50
It is really a lot of stuff to buy! I am looking at the price and all together is around 500 euro (Schalk + Bticino probe)! But it is quite interesting Mark! I want to know more about the data acquisition (analogue value) if you have the info please share! we can write a dedicated post for it. What do you think? And Where did you buy all this equipment? Online? (I am in the Netherlands) and I am struggling with finding them online!
The electric scheme will be also very interesting. Is there any way that you can share it? How did your electrician connect all this? I am also interested in the interfacing with Bticino!
For the scenario, I am still busy with it! No time so far!
I want to keep this forum alive because I see a lot of good motive to keep Bticino knowledge. Thanks for your effort!
m4rky_m4rk
None of this stuff is cheap. There was another make that was similar, maybe a bit cheaper as the switches for the sensors were all in one unit. I cant remember the name. Maybe Tom does if he comes by.
For analogue value on the BUS.. I do not know much about it but Tom and some others wanted to go that way. Try PM'ing him. I get analogue data via a separate system and app. Its independent of the BUS and good for cross checking my weather limit swicthes, charts, max, min etc
A dedicated post could be good if we can get a discussion going that is not just me. Especially with the new BTicino driver... again Tom and some others.
My installer recommended the Schalk. He said BTicino would support him with the install if he used it. The support actually consisted of example MH202 scenarios to run the gear. I took a look at it, understood what they had done, and then went my own way.
I had already planned for sensors during the house build and had allowed for cable access to the roof. They could be placed anywhere really as long as it doesn't affect the wind too much.. ie not in the lee (sheltered side). Other than that you just need a little bit of space in your rack. The temperate probe is wireless so cables needed for that.
I think the sensors really bring the automation alive. You can do a lot with them,,, if blind control is important to you.
Tony50
Mark, I finally finished the installation of the Schalk sensor. I do have the same configuration that you have. I also connected the 3477 to them. Now I would like a bit of support on how to configure the scenario in myhome and how to configure the 3477. Can you help me out with that?
m4rky_m4rk
Sure, what do you want to know? Have you a plan on how you want to utilise them?
eg
I use them for mainly for blind control, maximum light unless the house is getting too warm, and protection from thunder storms.
m4rky_m4rk
Just choose a unique contact number for the F428 ... I think only 1 to 9 are allowed.
On S10 panel add a new Contact object under the Automation items tab. Set the contact to be the same as chosen for the F428. Drag the item to the screen, save an upload.
Thats it
gugus24
Hi M4rky,
Thank you for your remply.
On the F428 I only have 2 channels (Do you mean channels by talking about contacts ? )
Does this have to be done on MyHomeSuite or on the Touchscreen directly ?
m4rky_m4rk
2 channels but you can assign each of them a unique contact number with virtual configuration (MyHomesuite) I am not sure if you can also do this with configurators
gugus24
Thank you M4rky,
I only use the virtual configuration, but I don’t understand what you mean with this contact assigned on each channel.
gugus24
Great !!!
Thank you M4rky !
I have used this channel as Light Control, because this channel is connected with an Eltako Sensor for the Sunset. This should turn on my outside lights. At the beginning was expected to start a MH202 scene but it didn't work. The scene didn't start whithout any known reason.
So is it then possible to also use it as contact to turn on the light (or start a scene) like I actually have and also show the status on my Touchscreen by using 1 channel ?
Another question :The option "Number of contacts" means that x contacts are numbered or is it a reference like an adresse (ex : contact number 6 and not 6 contacts) I do not really understand the meaning.
Thank you in advance for your great help M4rky !
m4rky_m4rk
Yes its possible do do what you want. I do the similiar
This is the simple one:
Maybe you have something wrong. Start simple and build up. eg remove anything in the 'Only if' section.
I don't always get the sensor state to activate a scenario directly. eg I use the sensor to change the state of a proxy switch. That makes it easier to visualise what the system state is without the S10 eg phone app, and it also means that I can overide the sensor and activate the switch manually to check that the main scenariuo runs as it should.. eg for testing.
On my S10 I have both the 'wind' contact and the 'wind' switch displayed next to each other so I can see if they are in sync. This also means that I can test, or if I see a storm coming, activate the Wind protection scenario without actually waiting for the wind sensor/contact to change.
gugus24
You're great !!
This means that my F428 status remains on 'ON' status as long as my Eltako sensor sends a Sunset signal ?
m4rky_m4rk
Yes. The F428 senses if the contact its connected to is open or closed. They can also be used to add BUS control to traditional switches.. if anyone else reading is curious about this stuff :)
For sunset/dark I also use the dark theshold to turn on some lights and close the blinds. I use the bright threshold to add more inteligence to my blind control on sunny days. For sunrise I prefer the Astro clock.
gugus24
Scenario's shouldn't loop unless you have the 'Repeat' option set to 'yes'!! Its top right of the screen under the scenario name and description. Both options should be 'No' for your lamp situtation.
Normally the scenarios just run through the sequence of 'Actions' and then stop when they get to the end of the sequence. Then they will only start again if the start condition occurs again. There should be no need for the stop command.
If the Repeat option is not selected then I am puzzled. In that case could you post a screen shot of MyHome Suite.
Stop panel is used to interrupt a already running scenario. eg when you want to start another scenario which has some of the same items in the action list as an already running scenario. eg blinds with staggered closing and then another scenario starts to open them. If you do not stop the first scenario then both scenarios could run at the same time causing confusing results. FYI Up to 5 scenarios can run simultaneously.
For debugging and testing you can see what is running by accessing the MH202 via your browser and going to the scenarios tab. There all scenarios are shown with the running ones highlighted. You can start and stop them too.
For testing set the times around the time you are working on it and replace sunset with an hour. Then there is no need to wait for sunset or midnight to get a result ;)
Hi M4rky,
So I'm finally home to test your instructions.
I set the F428 plugged with my Eltako Sunset sensor with contact 1. The Eltako sensor shows a 'dark' status'. The Led on the channel 2 is not turned on.
On the MyHomeUp app I'm t rying to search the F428 to create a status display, but I cannot find any F428.
gugus24
Hi M4rky,
I just configured my F428 as contact but it seems not to work. The channel led has not turned on. Looks like the f428 doesn’t understand the eltako settings.
Do you know what the problem is ?
gugus24
Hi M4rky,
My F428 doesn't react. Do you have any idea what it can be ? My Eltako works on Sunset. But F428 doesn't start any scene.
m4rky_m4rk
Are you sure the sensor is switching and you have wired up everything correctly? The sensor has an LED, so you could play around with brightness level at sunset time watch it switch with the level setting.
I cant remember without looking but has the sensor got normally open and normally closed contacts? You could also test the F428 with a simple wire or dummy switch.
m4rky_m4rk
Sorry, I cant really tell from that and I have schalk sensors. But it lools like the Eltako has an LED indicator so you could check that the Eltako is sensing the light change. Also, it looks like it waits for 5 or 15min before changing the relay. Does it toogle the relay or pulse it ? Did the electrican test everything?
gugus24
Thank you m4rky for your response.
That's correct the Eltako waits 15 minutes on my configuration before sending the signal.
It toggles, because when I start a test on the Eltako, it toogles the relay.
You also talked on a previous mesage the possibility to add this F428 contact on the mobile app MyHomeUp ? Is that correct ?
m4rky_m4rk
I have two phone apps. atMyHome and Openhab. Neither support contacts but Openhab might in the near future. I put in a request with the binding developer and he has accepted it. So, if your interested in that please support the request at github.
The S10 supports contacts state visualisation but I don't know of anything else that does.
To get around this limitation I use proxy switches; as said in previous posts.
Proxy switches>>>>>> I use unused, unconnected, switch modules and create a scenario to switch these On/Off depending on a contacts state. Switch states are of course visible in all apps.
gugus24
Oh ok.
I think atMyHome and Openhab are Andoid apps.
But I don't understand the part with the proxy switches. Are those switches Bticino switches ? Do you have a reference ? You mean for examble switches from a BMSW1005 ?
m4rky_m4rk
Yes Android, no idea about Apple. I have avoided them since forever.
By switches I mean the standard actuator for lights and sockets etc. eg F411
Trending threads
Latest News
Netflix US subscriber growth slowed by competition
  • By Andy Bassett
  • Published
LG Mini LED concept TV unveiled
  • By Andy Bassett
  • Published
LG Display to start OLED panel mass production at China plant
  • By Andy Bassett
  • Published
Sonos to cease support for older products in May
  • By Andy Bassett
  • Published
Philips announces SN503, ST702 and SH402 sports headphones
  • By Andy Bassett
  • Published
