Bt945 - Quintro+
Discussion in 'Plasma TVs' started by zorg2000k, Jun 10, 2003.
  1. zorg2000k
    zorg2000k
    Jun 5, 2003
    361
    +15
    Was wondering if anyone has a BT945 - "QUINTRO+" ?
    http://www.b-tech-int.com/BT945.htm
    Thinking about getting one for connection to plasma screen through a JS RGB to Component Video (YUV).
    Any help would be great
    CIA
    Zorg
  2. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Have used one for a while, does what it says on the tin.
    Find 'em for a great price at Beyond HiFi ... look in Hi-Fi Leads_/_ Audio & Video Controls_/_ Scart Controls and Switches.
    The picture shown is for the older Quattro switch-box, but I've bought two Quintro+'s from them at that price, and can recommend them.
    Cheers, Carl
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    664
    In my cage
    +13
    I went through two of these both had problems with the wide screen swithing. I spoke to Keene Electronics technical manager who stated that the quintro is incompatible with some sony products. e.g. my Sony Sky digital box and playstation 2.
  4. MrAnderson69uk
    MrAnderson69uk
    May 12, 2003
    190
    +15
    I've been using one for ages. No real problems. The widescreen switching sometimes got stuck when flicking through NTL Digi channels. Solution was to go back to a widescreen channel and leave it for a short while. Then go back to a 4:3 channel and leave it to settle - then you should be sorted.
    I've been using it on a 7-8 year old KV S2952 and yeah the PS2 always switches to widescreen. But then again it happens when its connected to any TV, directly or via the Quintro+ ... thats just Sony for you as my other TV, a Sony 14" portable (swivel stand one) also switches automatically.
    Picture quality is good - and there's no noticable problems on my new Pio 433mxe. I've got NTL Digital (Pace 4000), Digital Sat (Dream DM7000), an Xbox and a PS2 looped through Sony DVD as there are only 4 RGB compatible inputs.
    Can't comment too much on audio quality as only the NTL box is connected via std stereo interconnects.
    Everything is set up for RGB and I use a JS RGB->VGA box to fead my panel.
    NTL is not too good due to their cheapskate broadcasting and high compression.
