jamesmiddle
I'm looking to get BT vision in a few weeks. My router is a couple of rooms away from where I want to put the BT vision box so I will have to connect it in some way.
I understand that BT supply a couple of powerline adapters for this, but how reliable are they? I've also seen mixed comments on whether or not they are fast enough.
I'm not adverse to running a bit of ethernet cable if thats a better solution.
What do you guys think? Stick with powerline or put in some ethernet cable?
Thanks, James
Thanks, James
