BT Vision remote code for samsung LE40M86BD
Discussion in 'Freeview & YouView' started by FizzleWizzleUK, Jan 22, 2008.
  1. FizzleWizzleUK
    FizzleWizzleUK
    Aug 31, 2005
    7
    +3
    Does anyone know the remote code for the samsung le40m86bd? (to control volume etc)
    I've tried all the codes supplied in the back of the BTV booklet and searched this forum but havn't had any success yet.
    I would really appreciate it if someone code supply me with the correct code.
    :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    23,632
    Lanarkshire
    +2,551
    It's possible the code for the Samsung isn't in the BT Vision remote.
  3. FizzleWizzleUK
    FizzleWizzleUK
    Aug 31, 2005
    7
    +3
    Its possible yes but saying as the vast majority of TVs are supported I was hoping for a positive outcome.
    I got the TV to pick up the remote (red standby button flashes on TV) so I must be close.
    Whats the range of values on these things? 0000-9999? I sincerely hope I dont have to go through all those but I may have to lol
    Again, if anyone knows the code then please post it here for myself and others.
  4. FizzleWizzleUK
    FizzleWizzleUK
    Aug 31, 2005
    7
    +3
    I finally found the code that works. Posting it up in case anyone else is looking for it...
    Its 0111
    :thumbsup:
  5. stestretton
    stestretton
    Just registered incase anybody is googling for a samsung LE32R8 - it's the same as the above poster.
  6. Seedyranger
    Seedyranger
    Dec 25, 2008
    Same reason for posting as above, just to note same code (0111) worked a treat for Samsung LE32559P4, in case someone Googles it.
  7. gothgarg
    gothgarg
    Mar 9, 2008
    Ah! This is awesome man! I've been looking for this all my life.Makes life so much easier.
    :D
  8. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    Is that remark genuine or faecetious considering that today is the first time you've posted since March 2008?
  9. hilts01
    hilts01
    Jan 8, 2010
    4
    After spending several days frustratingly trying to find a code that works for my new Samsung PS50b530 plasma but to no avail, I thought id try this code just for hell of it. Whilst not expecting any luck at all and about to strike another possibility of my list, to my sincere surprise, Hazzar!!! it works, Well done FizzleWizzleUK. :clap:
    Poor show on BT's side of things for not being able to post the latest TV models with codes that work. 1 more reason to consider finding a new supplier for TV services. :nono:
