BT Vision Factory Reset info
Discussion in 'Freeview & YouView' started by Mad Mr H, Jan 18, 2008.
  1. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    Well came home tonight to find my BT vision box was stuck in standby - Orange light on front panel.
    Switch off/on at mains and still no joy.
    Called helpline on hold for 20 minutes.....
    BUT got some useful info.
    Factory reset - press "MODE" on remote, bottom left and then the "POWER" button at the top of the remote.....
    About 5 seconds later the box sprung back to life.
    Just thought I would mention this in case is helps others some time.
    (Mods please move if in wrong forum)
  2. Jason404
    Jason404
    Nov 8, 2006
    26
    London
    Was that a joke? That is not how to do a factory reset. That is how to turn it on, LOL.
    The Mode button just toggles between the mode for the remote to control the TV and the one to control the BT Vision box. You need to program the remote with the correct code for your TV manufacturer.
    To do a factory reset:
    1.Press & hold "OK" and Down Arrow button on box
    2.With other hand uplug power lead
    3.Wait 10 secs
    4.Plug mains lead back in
    5.Wait 10 secs
    6.Release buttons on box
    Warning: All settings and recordings will be lost.
