mark.crumb
Hello all
I have BT Vision and when I set it to 1080i some of the programs appear in 4.3 format even though the tv is set to wide. If I change to the built in freeview the same program will be in wide screen. However if I change the Vision settings to 4.3 format, the same picture through Vision is in wide screen, very confusing. I can set the tv to smart but then when you use the Vision tv guide, bits are cut off at the sides. The tv is a Sony KDL40v4000 which is connected via HDMI lead. I've had a look on BT's site but can't find a solution.
Any help in this would be apreciated.
Mark
Mark
