Yes, I will do. I tried on my Sony HW50 as was hoping to see how uhd Netflix downscales to 1080p but I think there is some hdcp 2.2 issue going on as I couldn't get anything working at all (my Yamaha Amp pretty much told me so but I managed to bypass that by using the front hdmi socket which must be the only non hdcp 2.2 socket it has)Thanks Soup, please let us know if/when it works in UHD.
I've a compatible tv but it also works on non compatible tv's/projectors too, but downscaled to 1080p. You need 4k, hdmi 2.0 and hdcp 2.2 on your display to get the uhd channel.If anyone wants this you will need an Ultra HD compatible TV. The list of current models is available here -
Ultra HD - TV compatibility and HDMI port settings | Help | BT.com Help
As long as your fiber is 44Mb or above you can get BT UHD.You also need a super duper connection - despite having BT fibre my connection speed averages around 48mb download - used to be much higher when I first got it but its been creeping down
So I was refused it - pretty disappointing really...
I wouldn't sit tight, BT would be fed up of me complaining, I'd take it as high as I could with the companyi would have thought so but when I try and do it I get 'computer says no' - I called them they said the same thing when I asked someone to explain why not - they couldn't.... I'll just have to sit tight for the time being![]()
Your drop in sync rate is more than likely caused by crosstalk as your cab fills up. Openreach mentioned introducing Vectoring to sort this problem but that was a long while back so I wouldn't hold my breath.You also need a super duper connection - despite having BT fibre my connection speed averages around 48mb download - used to be much higher when I first got it but its been creeping down
I wouldn't sit tight, BT would be fed up of me complaining, I'd take it as high as I could with the company![]()
I know that HD Netflix works with BTYV when purchased independently. Is it possible UHD only works when Netflix is bought through BT?I've a compatible tv but it also works on non compatible tv's/projectors too, but downscaled to 1080p. You need 4k, hdmi 2.0 and hdcp 2.2 on your display to get the uhd channel.
For reference, it's worth noting that the UHD channel is a marked improvement even at 1080p, simply because it's a higher quality transmission (the cameras are designed specifically for 4k tv for example) so it's still a good improvement even without a 4k display.
I don't know but it's worth checking out. Might post on the youview forum to see how others who are getting uhd Netflix did it.I know that HD Netflix works with BTYV when purchased independently. Is it possible UHD only works when Netflix is bought through BT?
No. Its totally independent. These are technical issues that can't be cured by making 1 or 1000 complaints. If ones line can't support it, it can't support it. Sorry.I know that HD Netflix works with BTYV when purchased independently. Is it possible UHD only works when Netflix is bought through BT?
But what if you are getting uhd channel but not uhd Netflix? Surely that can be cured?No. Its totally independent. These are technical issues that can't be cured by making 1 or 1000 complaints. If ones line can't support it, it can't support it. Sorry.
My suggestion is technically feasible. The UHD Netflix feed on YV may well come through the same server BT use for broadcasting their other UHD content. wish I knew someone who works on this.No. Its totally independent. These are technical issues that can't be cured by making 1 or 1000 complaints. If ones line can't support it, it can't support it. Sorry.
Just opened an email from BT. Looks like it needs to be connected to a 4k display to unlock the uhd Netflix option. I didn't get round to trying last night but maybe tonight...
Thanks. Pity that, as I already have Netflix UHD on my TV, I was hoping to see what it's like downscaled to 1080p on my projector.Soup,
I was going to say you'll need a 4K display definitately for the Netflix UHD to show,
Won't work on a full HD display.![]()
