photoboy72
Hi I wonder if anyone can help!
Just moved into an old farmhouse and although the broadband works fine on the test socket it seems as though there is an internal extension problem with the BT socket as the BT homehub doesn't get connection on anything other than the test socket. Inside the green is going 2 yellow to 4 and black to 5 but there is also a red or orange that isn't connected to anything. I am guessing this is the problem, but does anyone know where it actually should be!!?
Many thanks in advance....
