BT Infinity - Part IV
Discussion in 'BT Broadband' started by Curly99, Jun 22, 2012.
  1. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    This thread is a continuation of the part 3 thread here:
    http://www.avforums.com/forums/bt/1616874-bt-infinity-part-iii.html
    Last Post
  2. biohead
    biohead
    Mar 30, 2012
    234
    Bracknell
    +24
    I've had a quick look, and don't think I've seen this mentioned, so apologies if it has...
    Assuming you have the Echolife HG612 Openreach modem:
    The White Openreach modem is known to fail due to how hot it gets, mainly the early versions. The latest models (which ship with a white power adaptor) have a 3B on the back of them and are the most reliable version - although that could just be that they're too new to start failing yet. This is why wall mounting is very important on this Openreach modem as it will cook itself just sat on it's side. If it has cooked itself, it is permanent and irreversible bear in mind, so drop outs will not improve.
    If you have the other Openreach modem (The ECI model) then I don't think they're prone to overheating - but they're fairly rare at the minute so can't be certain.
    If Openreach have decided there's a fault in the exchange, it's best to leave them to sort that out first as it may be the cause of all your problems, and your modem itself could be fine.
  3. Stiff Dog TD
    Stiff Dog TD
    Dec 30, 2005
    102
    +10
    Been following all the infinity posts with interest waiting for our switch to go live, do I/do'nt I sign up. Well its now live so have taken the plunge, we have been told to expect 63.5 down and 20 up. We are only approx 300m from the cab and recently had new pairs and a new underground cable fed to the house, having worked on the digital region scheme and knowing how that system faired I look forward to the install on the 3rd July.
  4. Delvey
    Delvey
    Jul 20, 2008
    9,492
    Manchester
    +3,024
    The homehubs seem to fail as well, mainly the Ethernet ports. Anyone who has slow speeds should try it over wireless. If the speed is significantly greater than wired then the home hub needs replacing
  5. Delvey
    Delvey
    Jul 20, 2008
    9,492
    Manchester
    +3,024
    Seems like BT are another one to start blocking piratebay
  6. Scholes18
    Scholes18
    Oct 26, 2007
    4,062
    Republic Of Mancunia
    +419
    They haven't got a choice in the matter though... Required by the courts etc
  7. BigNevster25
    BigNevster25
    Jul 21, 2006
    332
    South London
    +30
    Hi there,
    Need some advice,
    Had Infinity for a while and have been told by various people to get rid of the HH3, could anyone please point me in the right direction to get a decent router??
    Thanks in advance
  8. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    What problems are you having with the HH?
  9. BigNevster25
    BigNevster25
    Jul 21, 2006
    332
    South London
    +30
    As im a online gamer I have been getting lag issues and some people have blamed it on the HH3....
  10. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,550
    2
    In a secret location with Jennifer Lawrence
    +11,946
    Mine has been fine. My ping is a lot better than my old o2 connection.
  11. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    What have BT said about the issue?
  12. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,863
    127.0.0.1
    +7,680
    I play a fair amount of online games and haven't had issues with the HH3. Some servers give me pings lower than 15ms (sometimes touching the high single digits) which bearing in mind my ping to the HH is 4ms (powerline adapters) is crazy.
  13. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    Seems a compete waste to spend cash on a router, when the HH may not even be faulty.
  14. menz83
    menz83
    Apr 20, 2006
    2,383
    Aberdeen
    +207
    Well after 5 days of issues with my new infinity install, an engineer came round this afternoon to get things sorted. I complained of continual dropouts and a sub 14Mb ip profile. The engineer done some tests and noticed that my AC line balance was currently at 40db with 55db or above being deemed acceptable. The engineer was very thorough and did tests at the cabinet and out in the street somewhere, changing the line pair or something along that lines and this improved my AC line balance to 60db! He did get everything up and running again and his equipment showed an ip profile of 20.5Mb. After some further tests, he received a text stating a profile of 19.5 but a quick bt speedtest on my laptop showed a profile of 18.88!
    The engineer was still concerned that the problem might not go away. I am 1280m from my cabinet and whilst that distance should provide some pretty good speeds, my area is covered with aluminium lines rather than copper which degrade much quicker over shorter distances. I was told that if things stabilise at 12Mb I should be happy with it as I was only achieving 5Mb with adsl. My upload speed has more than doubled to around 3.5Mb and I am fairly happy with that, but my estimates were 21.5/5.4 so it is less than what I was hoping for. Here's hoping that fttp on demand is cheap when its available next year!
  15. deathtrap3000
    deathtrap3000
    Oct 17, 2008
    1,441
    63
    London
    +152
    The results the engineer gets are the actual sync speeds, not the ip profile.
  16. menz83
    menz83
    Apr 20, 2006
    2,383
    Aberdeen
    +207
    Thanks for that, looks like im much closer to my estimate after all. Connection has been rock solid all afternoon too which is good and im currently downloading a few things at just under 2.2MB/s which is something ive never seen in my life!
    Wireless speed from the HH is a bit slow though, cant seem to connect at anything quicker than 54Mb. That will be a major pain when copying stuff from my NAS!
  17. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    Are you connected with a Wireless N device?
  18. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    I thought the minimum BT had agreed to offer with Infinity was 16 or 17Mbps....
  19. menz83
    menz83
    Apr 20, 2006
    2,383
    Aberdeen
    +207
    Its 15Mb however if you sync lower and are willing to accept that, you can still have it according to the engineer I spoke with today. I guess if you're used to only 2Mb, anything near 15Mb would be pretty good. When I dropped below 15, they pretty much immediately agreed to send an engineer round as my speed had dropped below acceptable levels.
  20. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,863
    127.0.0.1
    +7,680
    This. They eventually allowed it and it's pretty much on the basis you take whatever you're given
  21. Delvey
    Delvey
    Jul 20, 2008
    9,492
    Manchester
    +3,024
    Give it a few days and reset the modem
    The line might have settled by then.
  22. BigNevster25
    BigNevster25
    Jul 21, 2006
    332
    South London
    +30
    BT said they will turn on Interleaving??, i thought they could not do it on Infinity??
  23. deathtrap3000
    deathtrap3000
    Oct 17, 2008
    1,441
    63
    London
    +152
    The limit is 15mbps. If you are predicted less than the they dont initially offer it to you. The instead offer you a different service called BT Total Broadband with Fibre. Not classed as infinity but still provided in the same way. If you get less than 15mbps on an infinity install they arent meant to continue.
  24. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,863
    127.0.0.1
    +7,680
    Why do they make such a fuss over differentiating them? That's what I was on and I kept just telling them it was Infinity because I was getting over 15Mb but they didn't understand. Now BT have realised I get more than 15Mb they just call it Infinity though :confused:
  25. Carlow
    Carlow
    Oct 17, 2009
    1,349
    +317
    time to flip the coin and see weather i stay with sky or go back to BT ;)
  26. everett_psycho
    everett_psycho
    Nov 20, 2009
    8,098
    Christchurch NZ
    +2,623
    Did this actually happen or have they pushed your date back like they did with most others that said the 30th June? I'm tempted to ditch sky and go to BT mainly for infinity if it ever arrives and hope they offer up a good youview bundle
  27. southbank72
    southbank72
    Sep 18, 2007
    10
    3
    whats the best way to check what download speeds I'm getting as I had BT infinity installed today? I have been on speedtest net which came in a whooping download 73 Mbps http://www.speedtest.net/result/2045722135.png, however broadband speed checker came in at 34Mbps , think broadband was 12 mbps , uk broadband speed test was 32 Mb , broadband watchdog was 20 Mbs ..............how can they all be so different ? i have no idea my sped , any help much appreciated
  28. deathtrap3000
    deathtrap3000
    Oct 17, 2008
    1,441
    63
    London
    +152
    none of them are accurate. you can check your ip profile on the bt speedtest site and that will get you a good indication of what you can expect to almost achieve. Try downloading a few things at once from a reliable source and add them together to get a figure.
  29. messenger
    messenger
    Mar 28, 2006
    1,255
    Southend-on-Sea
    +204
    Im sick of these Java/Adobe/Flash speed testers, their so inaccurate & give many people a false impression of their newly installed broadband connections.
    I guess they are the best we have without actually downloading something but as the post above says try downloading a few things at once from a reliable server & add the figures together or just fire up a Usenet reader & prepare to max out your connection.
  30. jwalsh82
    jwalsh82
    Jan 16, 2008
    4,063
    Brighton
    +353
    I have to say I am mightily impressed with BT Infinity.
    Estimated speed of 58mbps, but Speedtest.net show me at 80mbps when I go wired. My 200mbps powerline
    adapters from downstairs to upstairs, still give me between 55-60.
    My wireless is only 20mbps, but I don't have an N card.
    iPad and iPhone get's about 30mbps.
    Very happy with the speeds, service and install.
