Hey there guys
Basically i have the bt home hub *trust me i hate it as much as alot of you do but long story* anyways i was under the impression it would be fine to use wifi with this hub.
It also shares its connection with the pc downstairs through LAN.
Anyways when it comes to wifi im useless
the pc with the home hub doesn't have a wireless card i dont know if that was needed but the ds can't pick up any useable access point. Iv tried turning off the firewall but nothing happened there and the wireless signal on the hub is flicking green.
Iv seen the nintendo wifi usb adaptor and im wondering if its worth my time buying this as *from what iv heared* its easy to set up and will let me have wifi.
Thanks for any responses
