shoehorn
Established Member
I've just moved house to an non-NTL area so now my broadband is through BT, however they've just told me that my Linksys WRT54G wireless router is now redundant.
Can anyone let me know if this is right please?
And can anyone let me know what to do if I can use it again?
With cable, the STB had an ethernet connection as does my Linksys - so it was simply ethernet to ethernet.
Now, the cable from the microfiter is not ethernet and will only plug into the BT modem/router.
So, I set everthing up, including installing all the software that came with the BT modem/router and plugged the ethernet connection from the BT modem/router into my Linksys (Internet port), turned it all on, hoping to connect to the internet, but it didn't.
I unplugged the ethernet cable from the linksys and put it into my PC. Then I had internet access, but only on that PC.
I need to use my router, as I have another PC and an MP101 that are both wirelessly connected and a hard wired showcentre.
When I use 192.168.1.1 (I think that's the number) in IE I now get the BT router... whereas before it was the Linksys.
My Linksys still forms a wireless connection to my PC, I can see it on the PC, but my showcentre fails to connect to the sever anymore.... I didn't check the other bits as it was late..... I was frustrated too....
Any thoughts please?
Thanks...
Thanks...
