BSOD issues
okay so i keep getting blue screen of deaths, they seem pretty much random, no real pattern.
sometimes after exiting a game, sometimes when its been left on overnight it crashes during the night.
i recently ran disk cleanup which deleted all but todays bsod so im posting todays one in hopes someone can help.
will post others as they occure.
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\062710-21734-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`03062000 PsLoadedModuleList = 0xfffff800`0329fe50
Debug session time: Sun Jun 27 11:14:11.109 2010 (UTC + 1:00)
System Uptime: 0 days 16:01:06.281
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {ffffffffc0000005, fffff800033c651b, fffff88003350a48, fffff880033502b0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+36451b )
Followup: MachineOwner
hopefully this makes sence to someone.
will update as bosd's occure but sometimes goes a few days being fine and dandy
yeah i know its silly really.
i think 90% of the issues are a result of the power supply unit and fact its only on 2gb of ram.
cant do a clean install because my product key is on its last use lol.
ahhh also drivers are all up to date
mdbarber
whats the thing with the psu?, also whilst having less ram is restrictive 2gb is more than enough and won't cause any bsod issues.
its a 700watt cheap peice of turd psu lol
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
