BSG Season 4 question
Discussion in 'Shopping, Deals, Discounts & Bargains' started by d3moliti0n, Jun 8, 2009.
  1. d3moliti0n
    d3moliti0n
    Dec 1, 2008
    296
    +8
    Is 'The Final Season' DVD that has just been release the full season 4 or just the second half? Like, do you have to buy the original season 4 release and this 'Final Season' DVD to have the complete Season 4?
    Thanks for your help
  2. rojgelf
    rojgelf
    Jan 27, 2008
    8,167
    Oxford
    +1,369
    I think its just second half.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,695
    +3,172
    Season 4 and the final season on DVD make up all the episodes from whole Season 4. It is same as the US getting 4.1 and 4.2. As it is another way to get more money out of us and I only just bought season 3, I can wait until both are down to under £10.
  4. ubrain
    ubrain
    May 19, 2008
    303
    Camden, London
    +24
    Season 4 was cut short due to the writers' strike so they ran the first half as Season 4 and then, when they'd got the rest done, ran the 2nd half as 'The final series' but yes, in effect 4.1 and 4.2 for twice the price of a normal series (although there are quite a lot of episodes between them)
  5. rojgelf
    rojgelf
    Jan 27, 2008
    8,167
    Oxford
    +1,369
    Final season now £18 at amazon and play.
