Bryston launch flagship active speakers and new amps
Discussion in 'Hi-Fi Stereo Speakers' started by hodg100, Jan 22, 2018.
    1. hodg100
      hodg100
      Reviewer & News Writer
      Aug 8, 2005
      14,075
      3
      4
      +4,456
    2. ash23t
      ash23t
      Feb 10, 2007
      537
      28
      +89
      Bit confused here.
      Active speakers are 1 unit with speakers and amp bult into same cabinet as opposed to a seperate amp. A neater solution being one of the selling points.
      However Bryston are calling these speakers active despite no built in amp, sounds like they are seeing a rise in the popularity of active speakers and jumping on the labelling bandwagon.
      Am I missing something? Or are Bryston just being silly.
    3. sammy the squid
      sammy the squid
      Jul 5, 2009
      8,912
      Lancs
      +3,538
      Active speakers don't necessarily require the amp to be built into the speaker, although this is a common feature. Genelec as an example do various models (aiw26 for one) where the amp comes seperately.
      The speakers I own, Pro Audio Technology, (bi amplified actives) also utilise rack located amps.
    4. Legzr1
      Legzr1
      Oct 26, 2003
      972
      2
      43
      +155
      You’re missing where amplification actually happens in relation to speaker crossover.
      ‘Active’ speakers that have an amp bolted to the rear feeding internal passive crossovers are not, in my option, true active speakers.
    5. Mark.Yudkin
      Mark.Yudkin
      Sep 19, 2007
      9,967
      Zurich, CH
      +1,515
      An active speaker is about the topology, not the collocation of boxes. The topology of the Bryston, with a three way speaker, a pair of 3 channel power amplifiers and an active crossover is active, even though it physically occupies 4 boxes instead of 2, as can be seen from the technical description of the architecture. See for example Middle T Active Loudspeaker - Bryston.
      • Like Like x 1
      • Agree Agree x 1
      • List
    6. Paul7777x
      Paul7777x
      Jul 23, 2016
      2,494
      116
      North east. U.K.
      +714
      It’s the x-over that counts in an active speaker.
      As long as it’s digital (almost universally so) and splits the signal into separate signals for each individual driver before the power amp, and therefore each driver has its own tailored amp, then it is an active speaker regardless where the power amps are.
      Either on the floor or in the cabinet doesn’t matter, it’s the individual power amp driving of each driver that makes it active.
    7. DOBLY
      DOBLY
      Oct 30, 2006
      1,689
      116
      Dunedin
      +614
      This Bryston active system is similar to the PMC active systems that have been available for years - presumably the next evolution of digital crossover is the difference (minus the ATL cabinets), as the amplifiers for PMC systems were or perhaps still are of Bryston origin.
    8. ash23t
      ash23t
      Feb 10, 2007
      537
      28
      +89
      Thanks guys, didn't realise this.
    9. silouette
      silouette
      Mar 5, 2010
      686
      32
      Welwyn
      +82
      flippin expensive though for all the activity !
