Bryston 9B-SST vs. Theta Intrepid
Discussion in 'AV Receivers & Amplifiers' started by warrj, May 12, 2003.
  1. warrj
    warrj
    Has anyone heard both the Bryston 9B-SST and Theta Intrepid? If so, what was your opinion of the two amps (particularly if they were driving 'difficult speakers such as B&W Nautilus)? They're both around the same price (4K) and appear to have similar specs.
    Regards,
    Jules.
  2. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    I think it is wise to audition these amps yourself in your own system. It sounds like flogging a dead horse, but it is the only way. Don't mind what people tell you, they are both great amps. I think just looking at the specs (and techniques used) that the Bryston is a more load-tolerant and low-distortion design.
  3. bamber
    bamber
    Dec 2, 2002
    216
    16
    I haven't heard the Theta Intrepid or the Bryston 9B SST. But did do a direct comparison between the Theta Dreadnaught and the Bryston 6B SST/ 4B SST combo driving B&W Nautilus 803's/HTM1.
    I think the Theta was the overall winner IMHO with superb imaging. There wasn't much between them, I ended up going for the Bryston due the 20 year guarantee.
